Camber Kit For 17's on a 97 accord?
Old 04-06-2006 | 05:11 PM
bovabrandon's Avatar
Default Camber Kit For 17's on a 97 accord?
If i put 17's on my 1997 accord will i need a camber kit? Should i do 17's or 18's? Any one have them on with a drop let me know, i wanna do it right the 1st time. Thanks
Old 04-06-2006 | 06:36 PM
Breeze's Avatar
Default RE: Camber Kit For 17's on a 97 accord?
Hello bovabrandon
I have a 96 Accord and I put 17" on my car. I had to get camber kits for front and rear. i got these after the car had ruined four tires before the car was lowered. I ran them without camber kits for three months. No one told me at the tire place that I had to do this. I installed SPC performance camber kits and they were pretty pricey. You can find cheeper ones or you can shim the car with some nuts and washers. I had to get the SPCs because I was in the process of lowering the car. Regardless if your car is lowered or not I had found out that if you changed the factory rims and tires you have to have camber kits on front and back. Honda Accords have only toe adjustments and no camber adjustments. I hope this will help.
sofireguy
05-22-2008 03:40 PM
scribble
07-14-2007 12:14 AM
thunder_x
05-07-2006 01:57 PM
19accord95
02-11-2006 03:06 AM
