Different Brand Brake Rotors.
I am planning to replace my stock rotors but ran into a situation. Brembo only makes rotors for the front of my car and i'm thinking of buying Powerslot ones to accomodate the rear. Will it cause any problem for my car since they're pretty much OEM fitted and both drilled slotted rotors-? I drive a 2003 accord coupe. Thanks in advance for any help.
RE: Different Brand Brake Rotors.
as long as the grip pretty close to the same then it shouldn't be an issue... I don't think there will be enough of a difference between the two as long as you use the same brake pads front/rear...
