New accord looking for rims and tires
Question: Why 20" wheels?
- If for handling, please understand that your stock 17" setup will handle way-way better than a 20" setup; an 18" setup will probably provide the best all around handling.
- If for looks, please understand that you will be sacrificing a significant amount of ride and handling, and with less than a 3" sidewall you'll most likely find yourself replacing damaged tires (and possibly rims as well) on a fairly regular basis.
Hello Member
WheelBrokerAng ..
accordondubs.jpg?t=1318032769
2010 4cyl exl with 20s. Ride was fine and didn't lose much.... maybe 2-3 mpg hwy. I think I was running 225/40/20 tires. I have a 13 ex-l v6 now and I will be doing 20s again for sure.
I guess I’m too much the engineer (you know, the old "form follows function" thing) because I really don't get the attraction to big bling wheels (unless they’re needed to go around monster brakes).
Handling improved over the stock 17s, braking wasn't noticeably different. Only thing lost was a few mpg. I love how people try to talk from performance points all the time when these are street cars. Nobody is racing their accord. It would take a racing environment to notice the losses from changing wheels. People should just do what they want with their cars.
Like it or don't, believe it or not, there is a HUGE body of scientifically derived evidence that proves that your handling and braking were both reduced when you moved from 17" wheels to 20" wheels. Said another way, what you "think" you feel and what is reality are often two very different things.
Like it or not... a better, wider, stickier tire did help my car feel better on the road. When I put the stocks back on it felt clumsy and lost. I believe I have enough experience with it to know. Like I said.... in a track environment where you're driving to the limits of the car and the tires then maybe you could measure a loss in performance but in street driving conditions its not there. Try again.
You don't have to believe the science of the issue, but that doesn't doesn't change the fact that 20" wheels are less efficient on your car than 17" wheels, pretty much regardless of which performance category you're trying to measure.
