Pitted Brake Dust
I had that on some rims. I cleaned it up, peeled back the clear coat far enough so it was solid, then polished the aluminum. Then I used clear-coat touch-up paint (DupliColor I think). Didn't turn out all that nice, it was far from invisible. But I guess it helped prevent it from getting worse.
I think the only way to really fix it, is to remove ALL the clearcoat from the entire wheel & repaint it.
This Is A Good Way Too Do It...
Ive done this as Tyler says also..works pretty darn good..just take your time and they will come out pretty good...as long as the wheels are not cracked it will work well...
Use good paint, not that cheap 1$ cans at walmart(or else you will more than likely have an uneven look to it). Aircraft remover is the best way to strip the wheels down. 50 dollars a wheel is not a bad price, but you can do all the stripping yourself and save yourself some money. Do you have a local powdercoating shop? I had our local shop powdercoat the BBS wheels I had on my vette the same color as the car for 100 dollars.
thunder_x
09-13-2006 10:46 PM
