is it possible to use a spare tire with 17 inch rims?
Old 03-01-2007 | 02:38 PM
thunder_x's Avatar
Default is it possible to use a spare tire with 17 inch rims?
im getting my 17 inch rims installed today on my car, but i dont have a spare tire on it, and i was thiniing about getting one, but my brother said that the spare tire will be too small for these rims
has anyone ever tried that?
pics comming soon
Old 03-01-2007 | 03:06 PM
sir_nasty's Avatar
Default RE: is it possible to use a spare tire with 17 inch rims?
if you have 17 inch rims as long as all your tires maintain stock diameter you can still use the spare tire that came with the car. If your diameter exceeds stock then you'll need a full size spare (I.E. a rim with a tire that will be the same diameter as your 17's)
Old 03-20-2007 | 02:57 PM
Shadow1992's Avatar
If the reason you are getting 17' rims is because you have larger brakes, or are going to get larger brakes, than a stock spare will not work unless it's rim size is large enough to accomodate the brakes. But I would personally sugesst getting a fifth rim and tire, that way if you have to use a spare, you won't ruin your image by driving around with a steely on the car.
Old 03-21-2007 | 06:39 PM
1stAccord_2ndHonda's Avatar
just use one of your stock wheels and tires as the spare... i used my stock 13s as my spare tire when i had 17s on my old civic...
Old 03-21-2007 | 09:15 PM
poser_pilot6
Ive used my donut spare before with my 17s. No problems.
Old 03-23-2007 | 12:38 AM
Shadow1992's Avatar
Yes a smaller donut or stock tire will work as a spare with 17's, the thing I was trying to say is that if you have bigger brakes, the stock donut or tires may not work. Example: My 92 Accord came with 15 inch wheels and 10.5 inch brakes. Donut works fine for that setup.But I now have 13.5 inch big brakes, and the caliper prevents the stock 15's or donut from mounting. That is one reason I went for 17's myself. Plus they look really kick ***.
darkgreen18290
11-01-2010 12:44 AM
and4rik
04-29-2010 11:24 PM
mwalk20
01-13-2010 01:21 AM
brjoro
07-22-2009 08:24 AM
askingfornary
06-16-2007 08:37 PM
