Tire sizes
Old 10-17-2007 | 10:42 PM
tnguyen600's Avatar
Default Tire sizes
My uncle has a set of rims laying around with 225/35/18 on them.
Two of the tires are cracked, so im just gonna replace all four. The question is, rather then spending 150 per tire b/c they're low pros, can i just order some 225/40/18? They're less expensive plus not as low.
Old 10-18-2007 | 08:29 AM
falkore24's Avatar
Default RE: Tire sizes
http://www.miata.net/garage/tirecalcold.html
Use this link to compare the tire sizes. It should tell tou what you are looking for. Also compare to your stock size.
Old 10-27-2007 | 09:41 PM
They will not fit on that car in your profile..too big..you would have to roll the front and rear fenderwells to fit them on...
Old 10-31-2007 | 12:21 AM
mdnky
215/40-18 will fit better than those options, but there's less of a choice in that size. It's the closest size to the stock 205/60-16 size. Only a 1/10 of an inch difference in diameter (smaller than stock).
savedbyjesus
03-31-2013 09:34 PM
Frankly .....
04-11-2012 06:34 PM
Miscreant
07-30-2011 08:21 PM
cyclo
12-11-2007 03:53 PM
dj.fli4rt
05-30-2006 02:37 PM
