V-RATED
RE: V-RATED
Here is some info for you about those tires...
Most cars are tire tuned by the OEM manufactures by the suspensions, therefore they put on certain speed rated tires to tune the suspension handling.
If a tire dealer sells you a H- rated tire and your car calls for a VR rated tire, he can be liable for your accident should you have one....as a XXXX tire store owner I found that out the Hard Way.
You can put on what you like but the tire will not be the "RIGHT" tire for your tuned suspension as the lawyers see it...[sm=proof.gif]
WheelBrokerAng.....hope this made sense too you!
RE: V-RATED
Thank you my friend, as usual you are right with me.
As a dealer I could lose my living by recommending the wrong tire but most of all, my customers can lose their lives by also putting on the wrong speed rated tires..this is more important to me as a dealer than what brand a tire you would have on your ride.
I use both Yoko's on my cars and also have Kuhmo Ecasta 712's on one of my other cars..
So I like Kuhmo tires also..but I like safety in what I sell for the correct speed ratings from the manufacture...
WheelBrokerAng : My Honda in this picture has Kuhmo's on her...
[IMG]local://upfiles/22/C3D7A856A28740208A936BE7975F6A23.jpg[/IMG]
ORIGINAL: RTexasF
My advice is to listen to WheelBroker. Why play with the manufacturer's original specifications? As a dealer he could lose his living by recommending the wrong tire.
RE: V-RATED
WheelBroker -
This thread brings about a question.....
The Michelins that come standard on the '04 Accord 4cyl , MXV4 Energy 205X60X16, ride pretty rough. Is there such a thing as a V rated tire that has good wear, traction, and temperature numbers that rides well? I don't expect any V rated tire to be a pillow bed but these seem a bit harsh. I do run 35/33 psi which contributes to this but it sure helps in "spirited" cornering.
