What size tires for 18's?
Old 10-24-2005 | 11:51 PM
Accord5726
Default What size tires for 18's?
I have an 03' Accord Coupe and I am wanting to get the 18x7.5 Konig Trouble rims and I don't know what size tire to get? I have been told to get different size tires, 215/45/18, 225/40/18.....what size? Thanks
Old 10-25-2005 | 12:18 PM
6thgen's Avatar
Default RE: What size tires for 18's?
225/40/18 would be a better performer. 215/45/18 would be a little softer. It has a wider patch and thicker side wall. Which translates into better grip and ride comfort. The reason you receive two different recommendations is because the 225 and 215 mm section can fit a +/- .5 inches larger or smaller than the ideal rim. The measured rim for a 215 is a 7.5" while it's 8" for a 225. Honestly you can run either one. You could probably run atleast three other sizes on the same rim and not effect the speedometer much.
cd75bus
10-27-2008 03:41 PM
cd75bus
10-23-2008 08:21 AM
jbrams
09-17-2008 08:44 PM
outcast
07-14-2008 05:05 PM
maro
03-10-2007 01:15 AM
