wheel diameter increase
I have a 1999 Accord LX (v6) with stock 15-inch alloy wheels and am thinking about going plus 1 or plus 2 to 16-inch or 17-inch diameter wheels. If at all possible I would like to stick with Honda OE rims. I know that these diameter wheels were offered on the 2004-2007 Accords and wondered if anyone has tried this, or know if it will work. I understand that the offset is a factor for clearance purposes, as well as bolt pattern. Thanks everyone!
Pete t
Pete t
RE: wheel diameter increase
Not sure, but remember it will mess up your speedometer/odometer (speed will read slower than you are really going & miles driven will show less than you have actually traveled). And the tires will cost more cause you'll have to buy them lower profile (if the wheels fit)
If the outter circumferance compensates for the rim size change, you can minimize or eliminate speedo error. See below:
http://www.miata.net/garage/tirecalcold.html
Thanks for the info - what I can't seem to determine is the compatability of 2003-06 16" oem wheels to a 1999 accord with 15" oem wheels. Bolt pattern and offset specifically. Anyone know where I can find these numbers? Thanks!
thunder_x
07-13-2007 05:20 PM
03Sleeper
06-30-2007 01:49 PM
