why do my tires keep...
Old 09-29-2006, 11:13 PM
DALAZ_68's Avatar
Default RE: why do my tires keep...
well the repairs were done properly and rebalanced so there fine
plus no mulah for it yet
Old 09-30-2006, 01:28 AM
I had the same problem and it was my chamber. What kind of rims and tires do you have? If they are not stock rim and tire chamber will be an issue. I purchased SPC chamber kits for front and back and ever since I did this I have even wear on all tires. Hope this will help.
Old 09-30-2006, 01:40 AM
DALAZ_68's Avatar
stock crappy rims with hub caps [X(]
Old 09-30-2006, 08:35 PM
RTexasF's Avatar
Super Member
Judging by the age of the car I would say that it's very possible that front end work is in your very near future. Over inflated tires wear out in the middle not the inner side.
Old 10-01-2006, 01:51 AM
deserthonda's Avatar
ORIGINAL: RTexasF
Rtex is correct...if you got too much inside tire wear,, there is too much negative camber and camber is not adjustable if it is off,, so Rtex might be correct again on worn suspension parts
My advice.........before you monkey around and try to correct the alignment.. install 4 new tires then have car aligned
Old 10-01-2006, 08:18 AM
DALAZ_68's Avatar
ORIGINAL: RTexasF
well the problem is inner not outer
rambleongirl
08-10-2009 04:21 PM
thunder_x
04-02-2007 11:58 PM
maro
03-10-2007 12:15 AM
thunder_x
09-26-2006 06:20 PM
Quick Reply: why do my tires keep...
