Will 18's fit my car????
Old 04-16-2006 | 11:23 PM
flomasta's Avatar
Default Will 18's fit my car????
SOrry if this is a repost but i need to know if 18 inch rims will fit my 1996 accord lx. 2dr.?? with no tire rub or problems?
thanks
Old 04-16-2006 | 11:48 PM
mbo1985's Avatar
Default RE: Will 18's fit my car????
If it's dropped a whole lot you may have problems. Should fit though, you'll just need some tires with very little sidewall.
Old 04-17-2006 | 12:13 AM
flomasta's Avatar
so do you think 215/35/18 or 215/40/18 would work and how much drop do you think would be to much?
Old 04-17-2006 | 12:39 AM
mbo1985's Avatar
probably the 215/35s. 2.5" is the max I would say for the drop.
If you don't have as much drop, the 215/40's should be ok.
I have 17's with 215/45's with no problems and a good 2-2.5 inch drop.
Old 04-17-2006 | 01:31 PM
Will fit your car with slight modifications to the front and rear fenders, if your not into rolling your fenders out then forget it and stay with a 17" tire and wheel combo..
Old 04-17-2006 | 03:11 PM
flomasta's Avatar
what do you mean roll the fenders? is it hard to do or cost much to get done?
Old 04-17-2006 | 05:30 PM
sir_nasty's Avatar
If you go with a 215/40/18 it should maintain stock tire size...
Rolling the fenders is basically where they take the fenders and bend or Roll the outside lip of them up/out a tad bit to allow more tire clearance.
Old 04-17-2006 | 08:40 PM
Yes it cost some money is best done by a custom shop who does body work.
Old 04-17-2006 | 10:32 PM
flomasta's Avatar
so the 18's will fit just fine with out modification to the body, as long as it's not lowered?
Old 04-18-2006 | 02:15 AM
SKHEMR's Avatar
I have a buddy with 225/35/19 on his lowered and his no problems with rubbing. 18's should be just fine.
